Adding Custom Properties
I need to Add and Modify custom properties in Solidworks.  I am new to Solidworks, but experienced with VB and VBA.  Can anyone point me in the correct direction?
RE: Adding Custom Properties
Here is some sample code to get you started. Updates the active document (part, drawing or assembly).
Option Explicit
Const swCustomInfoText = 30
Const swCustomInfoNumber = 3
Sub CodeSamples()
    Dim swApp As Object
    Dim Part As Object
    Dim sConfig As String
    Dim s1 As String, s2 As String
    Set swApp = GetObject(, "SldWorks.Application")
    Set Part = swApp.ActiveDoc
    'Define the Configuration
    '  -Use the name of the config if not default
    '  -You can get a list of all configs using:
    '       Part.GetConfigurationCount
    '       Part.GetConfigurationNames
    sConfig = ""    'Default Config
    'Get Current Value of Property
    s1 = Part.CustomInfo2(sConfig, "RevNo")
    If Len(s1) = 0 Then
        MsgBox "RevNo is Not Set or Not Defined"
    Else
        MsgBox "RevNo: " & s1
    End If
    'Store the Custom Property
    '   AddCustomInfo3 returns True if Added
    '   if False, the property already exists
    '   In that case, just update the value
    s2 = "2"    'Define RevNo
    If Part.AddCustomInfo3(sConfig, "RevNo", swCustomInfoText, s2) = False Then
        Part.CustomInfo2(sConfig, "RevNo") = s2
    End If
    Set Part = Nothing
    Set swApp = Nothing
End Sub
Hope this helps...
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Oops!
Setting sConfig = "" in the above code will set the Custom Properties, not the Configuration Specific Properties. You'll note that there are two separate tabs on the File>Properties menu. If properties are defined in both windows, the Configuration Specific will be used.
Looks great.  Thanks a ton.  I have been fighting this for nearly a week now.
