Mass Properties Question
Hello all, and thanks in advance for your assistance.
I have an empty metal cabinet design. It is made of 5052-H32 Aluminum. I would like to assign the density so I can get an understandable total weight of the cabinet.
Currently this is what is reported by the Model Mass Properities:
VOLUME = 1.8822252e+03 INCH^3
SURFACE AREA = 3.0173937e+04 INCH^2
DENSITY = 9.7912060e-02 POUND / INCH^3
MASS = 1.8429255e+02 POUND
I would like to decipher this and understand what it's saying. If I need to change the density and you know what the density value should be for 5052-h32 aluminum, I would appreciate you letting me know what the correct value should be. + any other info you think you should supply.
Thanks again for your assistance,
SrG
SrG
RE: Mass Properties Question
The density of most aluminum alloys is .10lb/in^3. Some people narrow is down to the individual ally but it's usually .095 or greater.
What else is there to deciper? The report gave you mass (lb=lbm at sealevel), density (lbm/in^3), volume (in^3), and surface area (in^2) for the object.
Tunalover
Change your density to 0.0968 lbm/in**3. (www.matweb.com)
Thats pretty close to what you have.
Taking the science out of rocket science...One step at a time.
