Process Water Mixing Rate
Good day:
I am working on a project utilizing a 12' diameter wet well receiving process water from a plant. No domestic sewage will be introduced into the well. The customer wants to intermittenly mix the wet well to collect a representative sample of the waste prior to pumping the wet well out. The side water depth may be up to 20' at times. I was thinking of utilizing a series of s.s. coarse air diffusers on the wet well floor to distribute the air. Any idea on the recommended flowrate and pressure for an air compressor or blower to provide adequate mixing?
Thank you.
Thank you.
RE: Process Water Mixing Rate
