Step Drills
Step Drills
Building a small enclosure. Looking for a low cost method for occasional use to put holes in 14 Ga sheetmetal box. Do the step drills work O.K.? I have some hole saws, but not in every size I need.
The punches are nice but are little over my budget right now.
RE: Step Drills
BTW, why on earth is this in the PLC forum?
RE: Step Drills
RE: Step Drills
as you go thicker than 14 ga you'll have more reason to use holesaws.
Torque can damage you, your drill motor, your workpiece, and your drill bit,,,, and step drills need all the torque you can get them. Scotty's right about using a drill press (pedestal drill) for speed reasons as well. Unfortunately I'm not enough of a toolmaker/machinist to be able to quickly tell you a good surface speed figure, or quickly explain how that works, but I'll make a suggestion. Metal cutting holesaws come packaged with information sheets, which give speeds (RPM) for use in various materials (Aluminum, steel, and SS are each VERY VERY different). Find one of those sheets and use the value given for whatever size your hole will be. A step drill is simply a "1 or 2 toothed holesaw", so it should turn at the same speed.
I've worked with dozens of "tradesmen" that still can't figure that out, so I'll leave it at that.
RE: Step Drills
RE: Step Drills
http://www
Great for non critical sized panel work, best used in a drill press w/ depth setting as to be safe.
Greenlee punch set for consistant results for standard panel hole sizes and adding holes in the field.
Dennis McHenney
mchenney@mindspring.com
RE: Step Drills
Ebay is your friend
