VFD's and motor rotation
we recently sent a motor out to be repaired. Just the other day we installed it on the same press we took it off of and the motor, when bumped, went in the reverse direction even though the phases were wired up correctly. My question is could the vfd that drives the motor have reversed the rotation or just simply the windings being mixed up at the motor repair center have caused this, also, have any of you ever seen this in the field? Thanks in advance for any replies.
RE: VFD's and motor rotation
