Shear wave Ultrasonic testing of 8mm thick plate butt weld.
I want to carry out SWUT of 8mm thick welds, do any one know about criteria and procedure for SWUT.
RE: Shear wave Ultrasonic testing of 8mm thick plate butt weld.
You need to consult a nondestructive testing professional that holds ASNT Level III certification for ultrasonic testing. They can perform the test for you or train someone at your facility to do testing.
