user defined functions in vba
how do i use a user-define function to calculate the value of e^x or N! in vba in excel.
RE: user defined functions in vba
TTFN
if i<1 then
Factorial=0 '0=error
exit function
end if
dim i as long
Factorial=1
for i=1 to x
Factorial=i*Factorial
next
end function
http://www.EsoxRepublic.com-SolidWorks API VB programming help
CODE
If inVal <= 1 Then
myFact = 1
Else
myFact = inVal * myFact(inVal - 1)
End If
End Function
But, short of doing a homework assignment, why would you want to duplicate a built-in function, particularly since your function will probably run 100 times slower.
TTFN
On my machine, the built in worksheet function took 1109 ms to run 100,000 calculations of FACT(170). The VBA routine myFact took 2922 ms for the same computation.
The overflow is only due to the variable typing. If you substitute double for long. The routine will work up to 170
myFact(170)=7.25741561530799E+306
It's not so bad as it looks, the function takes "only" 150-200% of the time the built-in function takes. Your point stays valid, though. Also, sticking to built-in functions will avoid "macro security" issues.
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
X=application.worksheetfunction.fact() there is an overhead cost in making the reference call. When comparing myFact to worksheet fact I found that myFact was actually faster for arguments less than 17. Above 17, the computational efficiency in worksheet Fact makes it a faster choice.
For instance, I use my own function for ATAN2, which works about 3 times faster than worksheetfunction.ATAN2() in Excel 2000, but about 8 times faster in Excel 2007.
This may be only temporary, until Microsoft fix the speed problems in Excel 2007, but for a frequently used function like ATAN2 it is worth using a UDF even for a 3 x speed increase.
Function VBAATan2(ByVal DX As Double, ByVal DY As Double) As Variant
CODE
VBAATan2 = -VBAATan2(DX, -DY)
ElseIf DX < 0 Then
VBAATan2 = Pi - Atn(-DY / DX)
ElseIf DX > 0 Then
VBAATan2 = Atn(DY / DX)
ElseIf DY <> 0 Then
VBAATan2 = Pi / 2
Else
VBAATan2 = CVErr(xlErrDiv0)
End If
End Function
Doug Jenkins
Interactive Design Services
www.interactiveds.com.au
