FORTRAN & VISUAL STUDIO -- Can Digital F work in VS6 or higher?
I am currently running Digital Visual Fortran V5.0 in a similarly elderly version of MS Visual (Developer's) Studio (ca. 1998). I also have a succession of newer versions of Visual Studio, through VS 2005. Is there any way to bring the old Fortran under the control of one of the newer versions of Visual Studio?
Tim.
Tim.
RE: FORTRAN & VISUAL STUDIO -- Can Digital F work in VS6 or higher?
Install MS Visual Studio first, then install the intel fortran compiler. During the installation it will recognize Visual Studio and it will embed its features in it.
After that, you will be able to create, edit, compile and debug any fortran code using MS Visual Studio.
__________________________________________
Everything should be made as easy as possible, but not easier
Albert Einstein
My intent had been to keep my old version of Digital Visual Fortran v5.0 -- which is licensed and works ok for my purposes. I just wanted to see if I could hook it up to a more current version of Visual Studio. But alas, that doesn't seem to be possible.
-Tim-
The problem is that MS changed the interface. On VS6, it half a makefile with some internal language for hints. On the later versions, it is XML. Since DVF was written before VS.net 2002 came out, it is not likely that it will have the relevant XML files to integerate into VS.net2005
I hate to admit it but it looks like I'm going to have to upgrade from my 10-year old software.
Regards.
-Tim-
If you don't need stuff like .net, proper STL library or C#, stay with VS6. It may look a bit dated but it is reliable and it works. Where I'm working now, they're still using VS6 for all development.
Could you post a link ? I can only find a 30-day evaluation download.
And according to the Intel web-site:
http://w
"Evaluation versions of IntelĀ® Software Development Products are available for free download. To get free support during the evaluation period, create an IntelĀ® Premier Support account now or after downloading the evaluation license. Please note that the product will cease to function at the end of the evaluation period, and the evaluation license is not renewable. "
Now I'm using Intel Fortran Compiler for Linux, that is free for non commercial purposes...
I thought it was the same for the windows version.
Sorry, my fault
Albert Einstein
It is not the same for Windows versions. You'll find that it is the same on a lot of products. The Linux version is free but the Windows version isn't.
There are quite a few free F95 compilers that will work on Windows for more than 30 days. I switch quite often between these:
g95
gfortran
Salford/Silverfrost - has PlatoIII IDE which is similar to visual studio.
If I want to do Windows GUIs, I use Silverfrost. If I want speed, I use g95. If I want to check compatibility, I use all three. Unfortunately none of them have anything to integrate into visual studio.
