Solidworks 2007 64 Vista 64 bit
4
Hi everyone. I am wondering if anyone else has tried this. I have successfully installed SolidWorks SP0 2007 64bit on Vista Ultimate 64Bit. I am running on a intel Quad Core 2.40 GHZ processor, 2gig of ram and nvidia geforce 8800 640 ram. All drivers are up to date. Solidworks is really slow causing glitches and stuttering on zooming using the scroll button, and when section viewing. I was wondering if anyone is having that problem. Or if anyone has any suggestions on how to fix this.
Thank you
RE: Solidworks 2007 64 Vista 64 bit
It sounds to me like your install wasn't as successful as you thought.
From SolidWorks:
SolidWorks 2007 will not support the 64-bit Vista operating system.  There is currently no commercial 64-bit version of Solidworks for Vista.  Support for a 64-bit version on Vista will occur at a later date.
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Thank you so much CorBlimeyLimey, that faq that you gave me solved my problem!!!! :)
Its working perfectly now that i enabled OPENGL
Thanks again :)
That proves that it is the video card or its driver which was causing your original problem. Upgrading to an approved card and driver combination will improve performance. Using Software OpenGL diverts valuable processing resources which could be better used elsewhere.
cheers
I actually tried that too, running Vista 64 bit, with both SW2007 and 2008. But in my case (proper opengl video drivers, etc) hardware opengl did not work.
You can use the Microsoft ORCA tool to modify the .MSI file to allow installation on any OS.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
Searching Eng-Tips forums
We were told that Vista 64-bit is not supported by SW and they don't plan on it as of yet. Hopefully SW09 will be... but that's a whole 6+ months away.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
how do u use orca to install SW ? where do i change "allow all OS" ?
If you don't need to play games now, then sell the 8800 with 640MB ram as quick as you can.  They just released a card (8800GT) in the $200-300 range with ~90% the performance of the top end card they make now.  Does have less memory though, but it's smaller (1 slot), runs cooler and on less power.  Hopefully they will make a lower priced Quadro out of that design.
Hi StefanHamminga, can u please explain how u got SW2008 to install on Vista 64bit. Im not being able to do it.
By the way is it running well on it? Do u have to enable open gl software like on 2007 to get better performance?
I was able to successfully install SW 2008 on my Vista 64 system, but when I try to run the program it fails... StefanHamminga are you running SW x64 or x32? Or does anybody have an idea why it's not working for me, other than the fact that Vista 64 is not officially supported?
My system:
Windows Vista Business x64
2.66 Quad Core
8GB RAM
Quadro FX 4600
Did you patch the installer per Stefan's last post?
cheers
I tested my method on both Vista Ultimate x64 as Windows Server 2008 (32 bit) Beta. No problems running, just crap performance in Vista x64.
BTW, I did this for testing purpose only, I'm running an unpatched SolidWorks (32 bit currently) on Vista Ultimate SP1 (beta) 32-bit. And on another install I run SolidWorks x64 on Windows XP x64 SP2.
I can imagine why you would like to run Vista 64 (I would like to as well), but SW is just not ready yet...
Stefan Hamminga
EngIT Solutions
I did not try out Stefan's patch because I didn't have any problems installing it (I installed SW08 x64). My problem occurs when I try to run the program, it won't start. But it looks like I'll have to just use XP x64 for the time being...
Guys just so u know, i got SW 2007 64 to work on Vista 64 ultimate, but i read somewhere that SW doesnt even really utilize multi threading, Just for hidden lines or something. So it might be even worth putting SW 64 on a 64 OS.
Multi-threading does not have really anything to do with 64-bit. Multi-threading is used with Dual or quad core machines. The only real advantage of 64-bit is the high amount of memory that can used on the 64-bit machines. 32-bit can only see up to 4GB and that's with the 3GB switch activated. with 64-bit I believe the limitation is 128GB of ram... but that number could be wrong, but I know that its so high it not feasible yet to worry about it.
Also even though you did get it to work if you have any problems with it... most likely it will be blamed on the OS your using.
regards,
www.scottjbaugh.com
I just wanted to mention that I tried Stefan's procedures using ORCA and have successfully installed 2008 x64 SP1.1 on Vista 64 business.  I have only been using it for a few days, but so far everything seems to work well.  Thanks Stefan for your suggestions!
Can any one explain how to do this for me?  I checked the link of Stefan, but it doesn't seem to be working, and I need to get this working.  I've only got 64-bit Vista, and can only get 2008 Solidworks, so without another investment (which I don't want since I'm just starting out) I'm screwed.  Any help is much appreciated.
SW2008-SP3 EV supposedly supports Vista x64, so you could sign up for the EV (Early Visibility) program. However, the production release of SP3 should be released very soon (this week ?), and SP3.1 (having full x64 support) should be released shortly afterwards.
http://www.solidworks.com/pages/services/CustomerBulletins.html
http://files.solidworks.com/Supportfiles/Release_Notes/2008/English/relnotes.htm#Windows_Vista
NOTE; even though the SP may give support, suitable video drivers may not be available.
cheers
Thanks!  I was actually able, after a couple hours of searching, to figure out the steps required from the clues given.  Installed and seems to be working properly.  I'll have to grab SP3 though...thanks again!
JRedH, did you get 64 to work or just 32? I tried to 64 working without any success, but I did get 32 working. If you got x64 to work, please let me know how. Thanks.
I can't view the patch that stefon wrote.  Do I need a login or something?
I got 2008 SP0.0 to work on 64-bit Vista Ultimate, and it appears to be working fine.
It involves downloading a Microsoft Windows SDK (found by searching for "Microsoft ORCA Tool" on Google, details can be found here: http://support.microsoft.com/kb/255905 ).
Once it's downloaded, follow the instructions on that page to install the tool.  Use the tool to edit the .MSI file for your language, which obviously involves copying the solidworks install DVD onto your hard drive to allow editing.
Directions on how to modify the file can be deduced from searching Google and coming up with this link: http://kbalertz.com/867629/Application-compatibility-testing-Windows-operating-systems-requires-changes-Windows-Installer-package.aspx
As I'm unsure the legality of posting step by step instructions for this, I'll leave it at that.  If you have any further questions, perhaps there's a more private way of communicating that would be less of an issue.
SP3 is now available, so the modified msi file should no longer be necessary if you use the full SP3 download.
Quote (SW Portal):
Feb 08, 2008       Microsoft Vista x64 support EV (Early Visibility)
SolidWorks 2008 SP3.0 now includes EV support for Vista x64. Select the x64 Edition from the Download Center. The full release will be with SolidWorks 2008 SP3.1 which will follow shortly after the release of SP3.0. For details see http://files.solidworks.com/Supportfiles/Release_Notes/2008/English/relnotes.htm#Windows_Vista
cheers
