Adhesive bonding of urethanes
I am trying to bond a thin film polyurethane to a cast urethane (shore A 28-42).  I'm looking for adhesive suggestions.  The bond needs to be watertight and survive 1-2 psi internal pressure.  Any help would be appreciated.
RE: Adhesive bonding of urethanes
Most urethane glue I have used are basically urethane dissolved in some solvent, aka MEK.  You can almost make your own ans spray it on.
