Use real image in render
Hello there!
This might be a trivial issue but somehow I am unable to find a solution.
I have a room modelled, and I would like to add a "window" to it... a cut in the wall that contains a jpg of a scenery.
I've tried applying an image to the sketch. This works fine, but doesn't show when rendered in PhotoWorks.
I've tried creating a decal but it comes out blurry and too dark.
Any suggestions would be very much appreciated!
RE: Use real image in render
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
Thank you both for a quick reply!
@Theophilus:
I believe I've tried what you are suggesting. However, I'll try again later and if unsuccessfull will post the proceedings. I'm probably missing something...
@Rockguy:
Image resolution is even higher than the final rendered image resolution, so I don't believe it to be an issue. Having said that, I apparently might have a problem with creating decals. It asks me for an image and for the image mask. Since it is not a logo that can be easily masked but a landscape, how does one define a mask for such an image? Could this be the problem why the image is blurry?
I will try your illumination tip, sounds promising! :)
Dan
www.eltronresearch.com
Sorry fellas, I was out of town. I've tried your suggestions and it worked like a charm!
Cheerz!
