thread inside a hollow cylinder
Which is the best thread style and type I can cut on a 0.02 thick 347 stainless hollow cylinder on the inside?
I want an extremely tight joint.
Thanks!!
Thanks!!
RE: thread inside a hollow cylinder
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
We need a little more information to give you any suggestions.
Heckler![[americanflag] americanflag](https://www.tipmaster.com/images/americanflag.gif)
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
o
_`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
What is the I/D of the tube?
What will this "thread" be mating to?
What forces will the connection be subjected to?
Can you quantify "extremely tight"?
Basically ... what are you trying to do?
You'd theoretically be able to come up with a 'special' UNS that would do it for any given diameter but practically this may not be appropriate.
You can play games on this link for days but it may not be a practical solution.
http://www
You say cut, I assume rolling something like a bottle thread isn't an option then.
KENAT, probably the least qualified checker you'll ever meet...
Steve Wagner
You're going to be limited as to how tight you can make any joint with walls that thin, no matter what the thread. This sounds like an application for an o-ring gland or a brazed joint.
Don
Kansas City
don't know how tight that'd be, and if the app is "nuke", don't think i'd like to think about it ...
if this is a permanent joint, bonding is a good choice
Is this a one-off item, or production?
Does the joint have to disassembled at a later date?
How much pressure is involved?
A "tight joint" for liquid or gas?
Etcetera, etcetera, etcetera
