A Drawing Problem
A Drawing Problem
A Drawing Problem
Hey guys,
I'm currently undertaking a project where I have to use VBE for Excel (which I'm not too familiar with). So the problem is... I've created a box (just a normal rectangle) for a graph and I have to draw scaled tick on... ie. marks for the axis' every increment. This is the suggested form...
Private Sub DrawScales()
    If the distance increment is greater than zero Then
        DrawDistScale distincrement
    End If
    If the elevation increment is greater than zero Then
        DrawElevScale elevincrement
    End If
End Sub
Does anyone know how to do this? I've attached the excel file so you can see what's going on... Just scroll down to the above section... Your help is greatly appreciated! Cheers,
Trent
RE: A Drawing Problem
Try this
    dblDistTick = frmProfile.txtDistTick.Value
    dblElevTick = frmProfile.txtElevTick.Value
    Dim dclicks
    Dim eclicks
    Dim counter
    Dim yloc
    dclicks = (frmProfile.txtDistMax.Value - frmProfile.txtDistMin.Value) / frmProfile.txtDistTick
    yloc = MARGIN_TOP + PROF_HEIGHT
    If dclicks > 1 Then
    For counter = 1 To Application.WorksheetFunction.RoundUp(dclicks, 0)
        If counter * frmProfile.txtDistTick * xScale <= PROF_WIDTH Then
            With ActiveSheet.Shapes.BuildFreeform(msoEditingAuto, MARGIN_LEFT + counter * frmProfile.txtDistTick * xScale, yloc)
                .AddNodes msoSegmentLine, msoEditingAuto, MARGIN_LEFT + counter * frmProfile.txtDistTick * xScale, yloc + 10
                .ConvertToShape.Select
            End With
            Selection.ShapeRange.Line.Weight = 1.75
        End If
    Next counter
    End If
    If dblElevTick > 0 Then
        ' Please insert subprogram here
    End If
End Sub
For your distance ticks.  You can use the same type of code for the y ticks.
How come you are not using a chart?
ck1999
