3d surface modeling
3d surface modeling
how do you convert 2d contours into a 3d surface model? can it be rendered by using visualization tools?
my goal is basically turn a 2d site plan drawing into a 3d model with materials attached in the drawing like grass,trees,brick walls,etc. for a perspective view presentation drawing, maybe a fly-by simulation if I have time.
thanx
thanx
RE: 3d surface modeling
Let me know.
Namdac
Next, reference the 2d file to the 3d file.
Copy the contours into the 3d file.
Change the elements to thier corresponding elevation.
Make sure that your elements are polylines.
Go to Tools>Surface Modeling>Create Surfaces.
Here you can take and interpolate between sections, and all kinds of cool tools you can use.
Namdac
Namdac
