Concrete Retards
Concrete Retards
I'm designing/profiling a 12" WL. There is a segment that will be very steep (25%) and requires concrete retards.. Has anyone detailed these? or where can I find stadard details/specs
RE: Concrete Retards
I think you are referring to cut-off walls, which are basically a concrete collar placed around the pipe to minimize groundwater flows in the backfill and bedding of steep trenches. In our area this expertise lies with the geotechnical consultant (soils engineer), who can size them and determine the frequency of their placement.
Basic guidance for steel water pipelines and designs etc. including piping on slopes is contained in AWWA manual M11, and the section “Anchors and Thrust Blocks” also contains the following statement, “An all-welded pipeline laid aboveground on piers may be stable when filled and under pressure but may require heavy anchorage at angle points and particularly on steep slopes to resist stresses resulting from temperature changes when the pipe is empty.”
I am aware of multiple projects where e.g. even very large diameter ductile iron piping has been installed on very steep slopes. The one I’ve seen the most detailed information on (with regard to supports/anchors and contacts etc.) was the installation of a 48” restrained joint ductile iron pipeline (used to pump a lot of Kentucky River water) up a steep “400-foot cliff” near Lexington, KY in the very early 1990’s. I believe a cut into solid rock was first made for the pier supports/anchors for that pipeline, by workers (with hand-held rockdrills and jackhammers) tied off to a life line with safety belts etc. After making the cut and drilling rock anchors several feet into same, concrete saddle supports were placed to support/anchor the pipes. Special pipe bands and rigging were fabricated that allowed the pipe to be lifted and suspended at the appropriate angle defined by the support saddles, and the system also allowed the pipes to be unhooked for assembly while the lifting device (a helicopter!) went to get another pipe. With this planning, I understand the actual placement of the ductile iron pipe up this cliff onto the supports subsequently took a total of less than six hours flying time, which made the cost of the helicopter services easier to bear. More information, pictures, and contacts etc. would be available through the pipe manufacturer, as the project was subsequently featured in the Winter 1993-1994 “Pipe Progress” magazine.
Beyond this, I would only mention that (like all other work and regardless of means of installation) I believe safety should be a paramount consideration and it should be remembered that particularly with work on a very steep slope virtually anything (even any tool etc.) of any size and mass can easily become a potent missile or bowling ball powered by gravity toward anything/anyone below! As far as basic slope stability or movement of water etc. along conduits or sloping conduits, this may be an arguably some different matter though I am aware that the USACE and probably also other folks have talked at length about this subject e.g. at least as it relates to issues of dams and dikes etc. (“anti-seepcollars”, “cut-off walls” or “water-stops” etc. might be good key words to find out more about such functions/applications). While not purporting to be an expert in the geotechnical etc. matters involved, I suspect however keying multiple substantial supports into a firm underlying structure (e.g. the solid rock of a cliff) of at least a non-leaking pipeline probably won’t hurt the future stability of the pipeline nor at least any soils between.
