PVRC Gasket Seating Stress
Does anyone have an equation from the Pressure Vessel Research Council for gasket seating stress? I have looked at a couple of references and have found a couple of equations that do not match.
Thanks for the help.
RE: PVRC Gasket Seating Stress
Probably be wise to post your question over in the pressure vessel forum.
The gasket seating stresses and the gasket factors are listed in table 2-5.1 of Appendix 2, ASME VIII Div.1. Those are conservative values and accepted for the design of the flanged joints.
However, I have been successful with the AI in adopting other values supported by the reputed gasket manufacturer (Klinger in this case), allowing a significant design reduction and cost saving for that particular flanged joint design (channel-tubesheet-shell flange design). Unfortunately, there is no formula available for you to calculate a convenient gasket seating stress and factor, these have to be either code allowable or guaranteed by the reputed gasket manufacturer in your area.
Cheers,
gr2vessels
