Standard Applied Weight Tolerance
I am testing a unit that requires a 50 lb reversing load in order to test axial lash. The test instructions say only to apply 50 lbs, they do not give any tolerance. Does anyone know of a standard weight tolerance that would apply in this situation? Where would I find that standard?
Thanks in advance.
Thanks in advance.
RE: Standard Applied Weight Tolerance
you might ask the manufacturer if it'd be a problem to exceed the 50 lbs
btw, "lash" = "back-lash" ?
Thanks so much
i think most people would accept that 46lbs is close enough to 50 lbs.
I think it was +-5% but can't recall for sure. We'd use this when doing calcs on aircraft stores.
KENAT, probably the least qualified checker you'll ever meet...
