excel vba
excel vba
I have a workbook with data in it that I want to copy and put in another wookbook. The data looks like this.
D11/22'2005
CX
T-7.80
PEl Azabache
LDining Out
(blank cell)
D11/22'2005
CX
T-9.50
PAce Hardware
LHousehold
(blank cell)
What I want is a macro to copy that data until it finds a blank cell and paste/transpose that data in another workbook and then get the next set of data until an other blank cell.
It should look like this when done.
D11/22'2005 CX T-7.80 PEl Azabache LDining Out
D11/22'2005 CX T-9.50 PAce Hardware LHousehold
D11/22'2005
CX
T-7.80
PEl Azabache
LDining Out
(blank cell)
D11/22'2005
CX
T-9.50
PAce Hardware
LHousehold
(blank cell)
RE: excel vba
assuming data in column a
sub helping()
dim jarray(100,5) ' Will do 100 sets
dim keepgoing as boolean
keepgoing=true
' Replace the 1 with whatever line the data starts in
counter2=1
for counter =1 to 1000 step 6
jarray(counter2,1) = range("a" & counter).value
jarray(counter2,2) = range("a" & counter+1).value
jarray(counter2,3) = range("a" & counter+2).value
jarray(counter2,4) = range("a" & counter+3).value
jarray(counter2,5) = range("a" & counter+4).value
counter2=counter2+1
next counter
'replace filename below with the filename you want to use and make sure it is open
workbook("book1.xls").activate
for counter = 1 to counter2
range("a"&counter).value = jarray(counter,1)
range("b"&counter).value = jarray(counter,2)
range("c"&counter).value = jarray(counter,3)
range("d"&counter).value = jarray(counter,4)
range("e"&counter).value = jarray(counter,5)
next counter
end sub
try this code
RE: excel vba
CODE
Set a = Selection
irow = 1
jcol = 0
For i = 1 To UBound(a.Value, 1)
strIn = a(i, 1)
If strIn = "" Then
jcol = 0: irow = irow + 1
Else
jcol = jcol + 1
Sheet2.Cells(irow, jcol) = strIn
End If
Next i
End Sub
RE: excel vba
Option Explicit
Sub CopyAndTranspose()
Dim CopyRange As Range
Dim cl As Range
Set CopyRange = Range("A8", Range("A65536").End(xlUp).Offset(1, 0))
For Each cl In CopyRange
If IsEmpty(cl) Then
cl.Offset(-1, 0). CurrentRegion.Resize(, 1).Copy
Sheets("sheet2").Range("a65536").End(xlUp).Offset(1, 0).PasteSpecial Transpose:=True
'Sheet2.Range("A65536").End(xlUp).Offset(1, 0).PasteSpecial Transpose:=True
End If
Next cl
End Sub
