Project to a point
Project to a point
I am needing to project a line onto a surface towards a point that is behind that surface. Is that possible?
ross.
ross.
RE: Project to a point
Set the line as element and the point as origin, set the ratio to 0.1 or similar. You will now have a line.
Use multi sect surf between the two line to create a surf.
Use intersect between your surface and the new surface.
Voila as our good frenchs would say
EXCELLENT!!!
