merging result files
hi all,
I have two subsequent analysis (static, end at time T1 and dynamic, end at time T2) on the same model. Is it possible to merge the relative result file to obtain and visualize a single output?
andrea
 Andrea Mordini, Civil Engineer, Ph.D.
 http://www.andreamordini.com
RE: merging result files
I think you want in the Basic Guide: Section 5.4.3 - Creating and Combining Load Cases.
This will allow you to operate linearly on any results sets of the same type.  These commands are denoted LCXXXX in general.  Look at LCDEF, LCZERO, and LCOPER in particular for your case.
before or during operation with LCxxx commands indicated by Stringmaker, you will most probably need RAPPED in some way.
