How can i set the model units by default???
Hi to all of you !!!
I trying to set the model units , by default in mm , ect , ect.
Because in pro-e the default unit is inch.
There is a way that can help me to set the unit once for all , without always set it ,before i start modeling??'
Tanks for every thing !!!
This is a great forum , greatly created and also greatly frequented by users!!!
Good job!!!
Regards!! bye
RE: How can i set the model units by default???
 put all your defaults in start part.. you should have one called mmns_part_solid.prt in your templates dir
Put this option in your config.pro file.
pro_unit_length unit_mm
There is also pro_unit_mass & pro_unit_sys.
Tanks a lot
Regards!!!!
