Local Rotating Region
I have accomplished doing an analysis of a local rotating region, but im am not being able to select the rotating part when it sketch a complex part. Only simple cylinder work. when i go to make a part that involves cut extrudes patters etc, to construct a real looking fan, i am unable to select the part as a local rotating region. I have read the tutorials and helps files many times, and i cant narrow down a reason why it wont work. Anyone have any idea what i should do?
