Infusion of resin at 30 poise to dry fabric tow
Dear all,
Does anyone know how of any technique of infusing a resin film with 30 poise viscosity (lowest in can go @ 250°F) to a highly compacted dry carbon tow of 24K strands? I've tried using vacuum bag at 28 in-Hg heat to 250°F and a dwell of 30 minutes but the core is dry. Will the use of positive pressure, say 85 psi helps? Are there any other technique available? Please advice.
Thanks!
Thanks!
RE: Infusion of resin at 30 poise to dry fabric tow
( Since you're making scrap now, at least try using glass until you get the process working. )
... Wait a sec; you're starting with resin in film form, e.g. b-staged, or you're trying to infuse a film- shaped cavity? Either way sounds like a non- starter.
Mike Halloran
Pembroke Pines, FL, USA
Agree with ewh, the composites forum is a better bet to get infusion experts' attention.
