Thermocouple Disconnects
I have an application that requires 40 type K thermocouples to be quick disconnected for equipment maintenance. I want to use four 24 pin connectors and box receptacles with gold pins and sockets. The type K thermocouple wire will be on both sides of the connection (Chromega+,Alomega-). As long as each pair of gold pins remain equal in themperature I should have offsetting junction voltages, and therefore no error in signal. I would appreciate a thought check on this, is it typical? Thanks in advance.
RE: Thermocouple Disconnects
