Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I'm a freelance consultant, and your site's helped me with many issues. I just wanted you to know that someone does appreciate the intelligent help your site offers."
Geography
hjulien (Mechanical)
19 Oct 07 13:44
Hi every body,
I'm starting in the Liquified Nitrogen vacuum jacket piping industry.  Can you suggest me good documentation as a start or good training offered by recognized organization in North America?
Thanks in advance,
hjulien
iainuts (Mechanical)
19 Oct 07 15:44
Hi hjulien,
Designing cryogenic systems or even just portions of such systems, such as vacuum jacketed piping, requires a background in a number of different but related fields.  You won’t get everything you need to know from one course.
For VJ piping I’d suggest first taking the ASME B31.3 piping code course since all VJ piping should comply with it.  This covers such things as pressure design, materials of construction, flexibility due to thermal contraction, etc…  You should take this course directly from ASME:
http://catalog.asme.org/Education/ShortCourse/B313_Process_Piping.cfm
A second course would be a general cryogenics course.  Can’t remember what I’ve taken now, but looking around the web, this one looks pretty good:
http://www.cryoco.com/cryo_eng'g.htm
You should also be very familiar with vacuum systems so I’d suggest a vacuum course such as this one, although I'm not recommending this particular course:
http://www.varianinc.com/cgi-bin/nav?products/vacuum/training/index&cid=HFIH
People you work with should also be able to direct you to what courses they would suggest and have taken, so ask around.
In addition to formal training, I think the best way of learning anything is to get a mentor at your place of employment that can help with your professional development.  Learning from someone on the job is probably the best way of learning anything in engineering.  Consider who you can work with carefully, the right person should be able to give you an education that is far and away better than anything you could recieve formally.
AlaskaMech (Mechanical)
26 Oct 07 20:52
Sir,
Like you, I hit the cryogenic field without formal training.
You need good vendor / manufacturer's rep. Someone that the manufacturer endorses. The Cryogenic Societies have links to VIP manufacturers.
You are not really going to design the piping. That can be procured via the manufacturer and his agent.
What you need to do is determine the basic routing and procurement requirements you need.
The advice to pursue B31.3 is good, but there is very little training available to design cryogenic piping.
Remembe that there are 2 basic types of VIP, passive vacuum and active (pump).
LSThill (Mechanical)
18 Nov 07 0:47
LNG Plant Operator Training Program, 2005 Gas Technology Institute
External Corrosion Direct Assessment (ECDA) Implementation Protocol
LNGFIRE3: A Thermal Radiation Model for LNG Fires.
GRI-GLYCalc Version 4.0
Energizing Sustainable Cities--The Power of Planning & Design (DVD)
Gas Interchangeability Tests--Evaluating the Range of Interchangeability of Vaporized LNG and Natural Gas
Lewis Shale Gas Resource and Production Potential
Erosion and Sediment Control Manual. Best Management Practices for Natural Gas Pipeline Construction Projects.
18 Nov 07 0:47
L S THILL
Close Box
Join Eng-Tips® Today!
Join Us             Close
