UG-116(b)(1) signification of letter P VS type of construction
Hi every body,
I really don't know how a ''P'' type of construction pressure vessel is done (see UG-116(b)(1)). What is ''pressure welded'' process? Is it similar to the Furnace welded type process? Can you explain me how this ''Pressure welded'' process works?
Thank in advance,
hjulien
Thank in advance,
hjulien
RE: UG-116(b)(1) signification of letter P VS type of construction
Check out the link below:
htt
Try the search "pressure welding" on any engine, say "Google" and please yourself reading many sites of the mentioned topic. It's realy easy..
Cheers,
gr2vessels
