listing nodes in contact
I want to list the nodes which are in contact or have penetration. I work in the Workbench Ansys 11 and just started using the possibility of commands. How do I list the nodes in contact or have penetration?
RE: listing nodes in contact
I sometimes use etables. For element CONTAC26 (no longer supported but still available:
ETABLE,gap,NMISC,3
then you can print using
PRETAB,gap
Rgrds
easier: insert a "Contact Tool", then inside the CT insert a "Gap" result (or a "Penetration" one, or a "Status" one as you need). Then, right-click and "Export" to Excel.
In the "Tools -> Options", you can find somewhere you can make Ansys export, together with the results and node numbers, also the nodes' coordinates (only in the global cartesian CSYS, however).
Note: the contact reaction force / moment is not obtained inside the "Contact Tool": you have to insert "Probe -> Force / Moment Reaction" and choose "Contact Region" as the Location Method (WB will then want you to choose the contact region in the "Contact Region" drop-down list, and WARNING: this list includes ALL the contacts defined, also those you may have suppressed...).
