Rock anchor in pier footing
Hi everyone
I am a new engineer in Australia, sometimes I see the bridge drawings shows there are some rock anchors in the spread footing of the pier, and would like to ask what is the purpose for this? In my understand, the pier only resist axial loading, and in the model, the base of the pier is set as pin. (all horizontal loads are transfer to abutment).
So what is the reason for the anchors in the pier footing? (is it used to control the min. column design bending moment?)
Also, any good book/papers talk about the rock anchor design? (bond between grout and rock face).
Thanks.
SayGoodDay
Thanks.
SayGoodDay
RE: Rock anchor in pier footing
Regarding the particular design procedures and such, I would check the foundation engineering forum and also contact some suppliers of rock anchors.
You will find that many engineers are moving to drilled shaft foundations as a more economical solution to several problems. - Good Luck
