aspen simulation of distillation column
HI, I was thinking of runing the simulation of distillation column in aspen, but since I'm still learning it, can somebody give me directions, do I need aspen dynamics, or aspen plus is enough. thanks!!
RE: aspen simulation of distillation column
You need AspenPlus user interface.
When u open the UI, select template and appropriate unitset for u.
Finish ur flowsheet.
There is a N> logo on the menu.Click it and it will walk u thro' all the inputs u need to put in.
You will need to input all stream data and column specifications.
hope this helps
