Extracting Points for Standard Deviation
  I have a bunch of points on a surface.  How can I validate that these points are on the surface or some distance off of it, then calculate the standard deviation.
QuEST / GE Mechanical Designer
RE: Extracting Points for Standard Deviation
you can use Analysis |Deviation|Gauge,checking to validate it.It'll helpfull.
  This is in refererenc to my orginal, "Extracting Points for Standard Deviation" posting.
  I uploaded a MS Word file with a handful of pics to better explain on what I'm trying to accomplish.
  As you should see from the pictures, there's a handful points that should be along the face of the profile that it outlines.
  I'm trying to determine if each of these points are actualy on the face & if the are not, what distance does it deviate from it.
  With collected data, I will probably calculate the standard deviation.
  Please suggest methods to produce accurate results.
