In Context Design
In Context Design
In Context Design
I've been using SolidWorks for several years. On my last project, I thought I'd try in-context design. I have basically 2 plastic parts - a bucket and a lid. (Visualize 5 gallon paint buckets). Plenty of ribbing and circular patterns. since I've started the in-context work, my machine has been real, real, real slow. Is this common with in-context design? BTW - 3 GIG machine with 2 GIG ram.
Thanks.
RE: In Context Design
Performance shouldn't be affected by using in-context design, but heavy use of patterns will definitely cause slow-downs. Using the Geometry pattern option, where allowed, often results in faster performance.
cheers
I've done many large in-context assemblies in the past without major slow-downs or performance hits.  The Limey and Jeff are probably right about the patterns.
Dan
www.eltronresearch.com
As a test, break or delete the in-context links to compare performance.
cheers
dadelar,
do you have some "stop lights" that won't go away even after you force a rebuild (cntrl-q)?
-Shaggy
I think those last two posts might help--although I've never had good performance on a laptop.  Watch for circular references between your parts--one thing depending on another that then ultimately depends on itself again--takes a long time to cycle through multiple times on rebuilds that way.  I'd guess you're seeing that issue--or dealing with typical performance of a typical laptop.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
Here are some good rules of thumb for in-context design (straight from Matt Lombard):
http://mysite.verizon.net/mjlombard/incontexttips.html
This one is key:
Quote:
always be concious of the circular reference problem.  If you don't use the layout part/sketch scenario above, then organize your assembly tree so the driving parts are clearly identified and at the top of the tree.  Make sure that the relationships always go up the tree.
-Shaggy
CBL is right you should test if not having external references makes your model faster...
Just one point, you may want to "LOCK" your external references see if it faster then "UNLOCK" them. If you break them they are gone for good, unless you have a backup of the file.
