Degassing isopropyl alcohol used in cleaning metal parts
I am a librarian in an engineering R&D company. A parts cleaner here has asked me to find an answer to a question. She is cleaning metals parts, mostly copper, titanium, stainless steel, phosphorus bronze, and brass. We are using isopropyl alcohol (2-propanol) for the cleaning, in the optima grade with 0.01% H<sub>2O. Are there benefits to degassing the alcohol and would degassing it reduce gasses significantly? Also, what can be some hazards, if any, of degassing at a temperature of 38degC (100degF)?
Thank you.
Thank you.
RE: Degassing isopropyl alcohol used in cleaning metal parts
