standard part dialog SLOW!!?
Hi everybody,
Does someone know why each time I´m openig standart part dialog, I have to wait about 10 second before dialog apear, and also when I choose the disear part I also have to wait the same among of time ??
IT´s very anoing and my guess is I chould have some option turn on or some programe instaled ?
I hope you can help me.
thanks
thanks
RE: standard part dialog SLOW!!?
If you are using mold wizard, I know in a few of the nx4 releases a few things act weird. Ug tells me that some of those things are fixed in the latest release of nx4 and nx5. Moldwizard will load all components that are not loaded in your ass'y, and will change most of your reference sets to entire part as well. So untill it is done doing this the dialog will not come up....
I'm not sure if this is what you're talking about..!
Brookey
I do have the latest version of NX4 and the preoblem is with moldwizard exactly.
I am not entirely sure that´s in fact what is apening on background but it might be it.
Is there a way to correct this error
thanks
Moldwizard doesn't have a preview, it's not like when you add a component with assemblies->add component.. It's a little bit different.
Well i´ve found my problem: i just change my default editor for exel files in costumers default from exel to xess.
It work just fine.
bye
