ASME Maintenance Codes
It appears there is a misconception whereby maintenance of petrochemical plants use ASME B31.3.
However, I know there is a specific ASME standard relating to maintenance of petrochemical plants.
My problem is that I forget what the standard is called.
can anyone help?
can anyone help?
RE: ASME Maintenance Codes
also API 579-ASME FFS-1, PCC-1, PCC-2.
L S THILL
The ASME Boiler and Pressure Vessel Codes address new construction. The ASME B31 Codes for Pressure piping also address new construction (however, B31.1 Power Piping has Appendix V which addresses maintenance, modification, replacement and repair of Power Plant piping systems.
The new ASME Post Construction Codes (PCC) will address the remaining life issues. Two PCC's are issued now.
Regards, John
