connection designer and detailer program...
I,m using STAAD.PRO program in designing multi storey concrete and steel building. Base on experience STAAD is good in concrete design. But in steel design it is good in designing for limited situation. Like, it is good in designing steel members but the problems is that the joint connection is not included in the design. Like for example vertical steel member connected to horizontal steel member and I want the joint connection to be bolt or weld connection. What will happen is that after I design it in STAAD I get the output and design the joint connection manually, that's drive me lazy if the building have a hundreds of joint connection to be designed it takes days or months to finish the design. And now I'm searching good software able to solve my problem.... Any body can recommend the software I'm looking for??
Thanks for any recommendations you may have.
RE: connection designer and detailer program...
RAM Structural System w/ RAM Connection
RAM Advanse
StruCAD (have not used this one)
SDS/2 (have not used this / Cadillac/Lexus/Mercedes/BMW of detailing software)
