Vibe isolation for machine mounted on wood frame floor
I have a 3-phase converter installed on the 2nd floor of an older wood frame building. The phase converter is essentially a large electric motor which weighs about 400 pounds. The installer set it on a rubber pad with bolts running down into a piece of plywood attached to the wood frame floor. You can hear the vibration throughout the whole building.
How do I isolate the vibration? I am leaning to housed spring vibe isolation mounts. Should I also try to add some mass with a concrete pad or something?
RE: Vibe isolation for machine mounted on wood frame floor
For more info check out this link...
http://www.fabreeka.com/tech/isolation_theory.pdf
"Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?" Oddball, "Kelly's Heros" 1970
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Note that the usual approach is to only get as low a natural frequency that will just reduce the vibration to a tolerable level, to minimize the translational motions.
TTFN
Tobalcane
"If you avoid failure, you also avoid success."
The design of the electrical connections will need to be reviewed.
Walt
Thanks to everyone who responded.
I didn't know you hung out here, good to see you...
Steve Schultheis
Steve Ciesla
http:
And like other's said, look out for mechanical short circuiting that limits the free motion of the unit on the isolators.
