API 1104 vs. ASME Section 9
On a crude oil pipeline station, when does API 1104 apply and when does ASME Section 9? On Welding Procedures, I am hearing two versions:
1) API 1104, till after the first above-gound flange, then ASME Section 9; versus,
2) API 1104 throughout ..."a pipeline is a pipeline"
RE: API 1104 vs. ASME Section 9
Look to the "Scope" section of ASME B31.4 & .8 to see where a pipeline starts and stops. You will see that "Pipelines" also include pump and compressor stations. Wether a flange is above or below ground makes no difference
http://virtualpipeline.spaces.msn.com
BigInch is correct, for entry to gas plant/production facility, typically the spec break will be at the flange of the side valve on the pig trap.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
Drawings should dictate where the spec change should be made.
you should not start to worry about section IX until you reach a processing facility or some form of packaged equipment piping.
it occured to me that you might be creating the drawing.
sorry, i'm on the construction end of the oilfield, so i'm used to drawings being completed long before i get involved :)
beautifully stated!!
State jurisdictions may impose further restrictions and may limit qualification to API 1104 only. For gas piping, Arizona mandates qualification per API 1104 both outside and inside of the plant; in power plants, B31.1 does not apply to the fuel gas lines.
