API 650 F & S Roof Design Stress with the Design Temp. exceeding 250
Any suggestion for choosing an allowable stress for an API 650 F and S tank with a design temp. in excess of 250 degrees.
The umbrella roof needs to be designed per API 620 but it tops out at 250 degrees F. and my design temp. exceed this by over 100 degrees F.
RE: API 650 F & S Roof Design Stress with the Design Temp. exceeding 250
Is the design temperature your major problem? Did you check out the API 650's Clause 5.10 and 5.10.3? Also, the temperature and material relevant Appx. M and S (refer excerpt Appx M below)?
"M.3.2 For a maximum design temperature exceeding 93°C (200°F), the allowable stress specified in 5.6.2 shall be modified as follows: The allowable stress shall be two-thirds the minimum specified yield strength of the material multiplied by the applicable reduction factor given in Table M-1 or the value given in Table 5-2 for product design stress, whichever is less."
Also, please refer to the Appendix A, the exerpt below:
"SECTION 5.1.1 SCOPE OF RULES
620-I-05/02
Background: API Standard 620, Tenth Edition, Section 1.2.1, states, “This standard does not cover design procedures for tanks that have walls shaped in such a way that the walls cannot be generated in their entirety by the rotation of a suitable contour around a single vertical axis or revolution.” This statement would appear to indicate that there are no design procedures presented in this standard for umbrella roofs, eccentric cone roofs and bottoms, and bottoms sloped to one side. For example, Sections 1.1, 1.2.5, 5.1.1, and 5.1.5, among others, indicate that subject to stated restrictions, designs that will be as safe as those provided by the standard may be used. This inquiry seeks to confirm this interpretation. I am trying to clarify Inquiry 620-I-10/00.
Question: Are umbrella roofs, eccentric cone roofs and bottoms, and bottoms sloped to one side, among those designs for which API 620 does not present design rules as noted in Section 5.1.1?
Reply: Yes."
Hope it helps,
Cheers,
gr2vessels
I don't see where I can ignore the API 620 temperature limits. In others parts of Appendix F, such as F.7.2 it specifically takes exception to 620's allowable compressive stress but I don't see where we are allowed to take exception to the temperature requirements of 620.
Thank you for the comments and please let me know if I am missing the forest for the trees.
Joe Tank
Thanks for the comment.
One of the previous interpretations to API-650 asked about whether you could pressurize an umbrella roof (as distinct from a dome roof) and the answer was "no". Not so much that it can't be done, but that the axisymmetric design rules in API-620 don't apply in that case.
