scale in title block
Hi All,
My name is Bruno, and I'm new to the forum. I have a question for anyone who can help me. I want to know how to make the scale appear in the title block of a drawing file. So far, the only way I've found to make it work is to go into sketch mode and place the text in manually. Is there a property that allows me to place this automatically?
RE: scale in title block
David
In your model tree, in the drawing resources folder, you will find a sub-folder titled "Title Blocks". In this folder is contained all the title block definitions that you have in your drawing template. You can either create a new title block or you can edit an existing one. If you choose to define a new one RMB on the title block folder and select Define New Title Block. You can then draw title block using the sketch tools. Or you can RMB on an existing title block and select edit definition.
Any changes you make to the title blocks are saved locally in the current drawing ONLY. That being said, once you have created or edited the title blocks, changed any dim settings and generally formated the drawing how you would like it to appear when you begin a new drawing, you can then save it to your templates folder as "Standard.idw", or any other name you choose. You can create as many templates as you choose but only the one titled Standard.idw will open automatically by selecting .idw from the New icon. It is in your best interest to save the Standard.idw that comes with Inventor under a different name or in a different location so that you can restore it if you need to.
If you are not sure where your templates are stored, go to Tools\Application Options\File and look at the Default Templates tab.
David
LMB = Left Mouse Button
David
thanks,
Bruno
