Pull-in voltage for square membrane
Hi
I've got a problem with electrostatic simulation. I've simulated square memrane 300x300x5um, under the electrostatic force using TRANS126 element. (see the script below) I took all voltage values from 0V to pull-in.
I've also calculated the pull-in voltage using an equation:
Electrostatic pressure = permittivity * voltage^2 / ( 2 * ( gap - deflection)^2 )
In many articles this equation is used and was also compared with ANSYS, the difference was very small.
Unfortunately I have a ~20-30% diffrence. Can anyone check my script?
FINISH
/CLEAR
/CWD,'C:\temp\ansys'
!* membrane
Lm=300
Wm=300
Tm=5  !* Epaisseur de la membrane 3e-6 / 1e-6
!* membrane_division
b=30
!* electrode_distance
h=-0.3
dif=20
!* voltage
v=10
/PREP7
   ET,1,SHELL63
   R,1,Tm
   ET,2,TRANS126
   MP,EX,1,130e+9*1e-6
!   MP,DENS,1,2330*1e-18
   MP,PRXY,1,0.278
   WPOFFS,0,0,dif
   RECTNG,0,Lm,0,Wm
   WPOFFS,0,0,-dif
   LESIZE,ALL,,,b
   TYPE,1
   MSHAPE,0,2D
   MSHKEY,1
   AMESH,ALL
   !* transducer
   NSEL,S,LOC,Z,dif
   CM,tr,NODE
   ALLSEL,ALL
   EMTGEN,'tr','EMTELM','EMTPNO','UZ',h,0,0.1,0.8854E-05
   NSEL,S,LOC,Z,dif+h
   D,ALL,,0,,,,UZ
   D,ALL,VOLT,v
   CMSEL,S,TR
   D,ALL,VOLT,0
   !* applying loads and BC
   NSEL,S,LOC,X,0
   NSEL,A,LOC,X,Lm
   NSEL,A,LOC,Y,0
   NSEL,A,LOC,Y,Wm
   D,ALL,UX,0
   D,ALL,UY,0
   D,ALL,UZ,0
   D,ALL,ROTX,0
   D,ALL,ROTY,0
   D,ALL,ROTZ,0
   ALLSEL,ALL
FINISH
/SOLU
   ANTYPE,STATIC
!* Pour prendre en compte le stress stiffening et les grandes déformations
!   NEQIT,100
!   CNVTOL, U, 1, 1e-3
!   NLGEOM,ON
!   SSTIF,ON
!   SOLVE
FINISH
/POST1
   PLNSOL,U,Z
   !* Récupération de la flèche qui doit être <= au GAP h
   NSEL,S,LOC,X,Lm/2
   NSEL,R,LOC,Y,Wm/2
   NSEL,R,LOC,Z,dif
   *GET,CENTRE_INFERIEUR,NODE,0,NUM,MIN
   FLECHE=UZ(CENTRE_INFERIEUR)
   NSEL,ALL
RE: Pull-in voltage for square membrane
The electrostatic pressure equation is correct.
I admit I have not analyzed your mac file in detail, but the following questions come to mind:
1) Does the transducer element support higher order terms O(x^2) and higher, if not it may only be a linearized approximation. If this were the case I would expect ansys to predict a higher pull in voltage than those reported in the papers.
2) Are the boundary conditions the same as in the papers? I see that you restrained the slopes at the edges.
