Parametric system
Parametric system
When I open my Pro/E parts in Solidworks all dimension changes with the factor 2.54. I can't seem to find where you can change to the metric system in Pro/E!
Would be glad if someone could walk me through my little problem?
RE: Parametric system
Edit-->Setup-->Units
For instance Go to your Solid Works settings and change them to Inch then try importing the Pro/E model and see if it comes in at the correct size.
Michael
