Prompted text entry order
Is there an easy way of changing the order of prompted text? The promted text form part of a template for a title blok. The block has been modified and new promted text items have been added. The new promted entry fields are added at the bottom of the prompted entry field block. The added promted text entries however relates to some of the old entries. The template would be more user friendly if the new prompted entries follows the relating promted text entries.
I am currently using Inventor V10
RE: Prompted text entry order
David
