math problem (sinusoidal motion)
Does anyone know how to solve the following equation:
-A*2*PI/6*COS(2*PI*t/6)-B*2*PI/18*COS(2*PI*t/18)=0
Where: A is a constant
       B is a constant
       t = time
Find: all values of t between 0 & 18 such that the above statment is true.
the function is velocity of a point subjected to sinusoidal motion of 2 frequencies & 2 amplitudes.  Times of Max. acceleration to design some hydraulic actuators to impart said motion.
RE: math problem (sinusoidal motion)
The answer is that it depends on A and B.  It's great that you say A and B are constant, but their values must be known before you solve this one.  There are no general t values that will work for all selections of A and B.
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
Ever heard of algebra? Trig identities?
(PI/3)*(-Acos(PI*t/3) - B/3*cos(PI*t/9))=0
PI/3 term drops out.  Let x=PI*t/9
-Acos(3x)-B/3cos(x)=0
use triple angle trig identity:
-4A(cos(x)^3)+3Acos(x)-B/3cos(x)=0
let y = cos(x)
-4Ay^3+(3A-B/3)y=0
Problem is reduced to a simple cubic.
from there it's even simpler ...
factor ...
y*(-4y^2+(3A-B/3)) = 0
y = 0, sqrt(3A-B/3)/2 (+ve and -ve)
and y = cos(pi/9*t) ...
Whoops, good catch, rb.  blush
That reduces it, guys, but you still have to know A and B to solve for t, which is apparently what he wants.
You can find at least *some* of the values of t without knowing A and B though, since the equation is looking for zero-crossings.
If both the cosines are zero, then the equation is satisfied regardless of A and B, since they are multiplied by 0.  Cosines are zero at pi/2, 3*pi/2, 5*pi/2, etc.  If you set the terms inside the cosines to n*pi/2, where n is an odd integer, then pi*t/3 solves to
t = 1.5 n
and pi*t/9 solves to
t = 4.5 n
where n is an odd integer.
The only time t<18 that both these equations are true is when
t = 4.5
This may not be the only solution, but it is a solution regardless of the values of A and B.
Don
Kansas City
i suspect that an "answer" in terms of A and B would meet the needs of the "problem"
Don, the complete analytical solution as completed by rb1957 yields your answer in the "y=0" solution that is independent of A and B, along with the other two answers in terms of A and B.  It is implicitly obvious that to find actual values for the other two solutions one must know both A and B.  However, the way the original equation was posted leaves me with doubts as to whether the OP is capable of following along and understanding the solution anyway.
my two cents: assuming 't' is real valued, then cos(pi*t/9) is real valued. If so, then Sqrt(3A-B/3) has to be real, and this is true if and only if the argument in the Sqrt is positive or zero, that is, 3A>=B/3, or A>=B/9 (that is, A is greater than or equal to B/9). This tells you not what A and B are, only that A has a constraint, it must be greater than or equal to one-ninth of B.
Hi guys,
Not to be a pill... but why are we answering something that is obviously a homework problem?
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
Its not a homework problem and I am perfectly capable of following the solution along.  I don't deal with these sort of equations on a regular basis as 99% of my work involves statics.  I was hoping for a little help to save me the time of digging through text books I haven't looked at in 10 years.  I know the values of A and B & posted the equation that way in hopes of getting an answer in terms of A and B so that they could be put in a spread sheet & get new values of t by changing the inputs.  Yes it is obvious that t = 4.5 is one solution & t = 13.5 is another.  I am interested in the other times when the cos of A cos(PI*t/6)=-B cos(pi*t/18).  If A=B t=2.25,4.5 6.75 etc. IF B>A the only solution is t = 4.5 & 13.5 .  But if A>B there will be 6 solutions t=4.5, t=13.5 & 4 others.  The 4 others are the ones I'm interersted in.  My lack of familiarity with trig identity functions prevented me from solving this equation in a timely manner.
Thanks for the help.
I'll chock up the condescending comments to not putting enough detail in my question.
rb1957 made a little mistake above, and it turns out that cos(πt/9)=±√(0.75-B/12A), so, when A>B/9 so the radical is real and is also <1, there are 4 more solutions besides the two obvious t2=4.5 and t5=13.5
The solutions are:
t1=(9/π)cos-1(√(0.75-B/12A))
t3=(9/π)cos-1(-√(0.75-B/12A))
t4=t1+9
t6=t3+9
Unfortunately scully44, if you looked for simpler formulae, that's it. However it turns out that t1 tends to 1.5 when A/B goes towards infinite, that it is of course equal to 4.5 when A=B/9 and that it is already =~1.76 when A=B. Similarly t3 tends to 7.5 (starting again at 4.5) and is already =~7.24 when A=B.
prex
http://www.xcalcs.com : Online tools for structural design
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
I would have taken the easy way out.
I would have graphed it over 0<t<18 and see where it hits 0.  This might have been tough if all you have available is a spreadsheet but most math programs could do this.  Took a minute or two to perform this in Maple and then you can manipulate the numbers to better model the system instead of just looking a few numbers.
prex made a little mistake in his factoring (at least the way i read his expression).  inside the sqrt i started with 3A-B/3 = 3A/4-B/12 when you bring the "2" inside the sqrt; ok.
this = A*(3/4-B/12A), not (3/4-B/12A)
Well rb1957, your expression
should be
y*(-4Ay^2+(3A-B/3)) = 0
so ...wink
It is instructive to follow this other way of reasoning: the cos() function results necessarily in a non dimensional number, so its argument must also be non dimensional. Now A and B may be dimensional (e.g. an amplitude, hence a length), therefore the quantity under the radical may only depend on the ratio A/B to be non dimensional...
It is BTW an evidence from the first equation presented by scully44 that the roots may only depend on A/B, not on their separate values.
prex
touche, another "small" mistake !
scully44,
hopefully the attached file will help you.  In this file, A=B=1.  So, you can change the values of A and B in cell B7.
You can use the Solver feature or maybe even the Goal Seek (doubt it) feature in Excel to further assist you.
Good Luck!
-pmover
