5 axis machining
5 axis machining
5 axis machining
I have experience with 3 axis CNC programming and would like to expand the knowledge to 5 axis programming.  I have access to Catia V5 and UG NX4 manufacturing modules.  Are there any sources available for tutorials that could be useful (or even books to help in learning)?
Thanks.
RE: 5 axis machining
If you want to learn how to use either the CATIA or UG....here is an affordable source.
www.myigetit.com
As far as learning 5 axis programming, well my friend, you just have to do it.
Working for a shop that actually has a 5 axis helps.
Good luck.
UG has a tutorial called CAST.  It is an awesome way to learn.
-Derek
