Part Thickness Limitations
I am building a part model of a PCB (printed circiut board) in Pro/E, and need to model individual layers so I can included the stiffness of my ground planes when I inport it into Pro/Mechanica.  The PCB is about 9.00" x 15.00", so it is a simple extrusion.  However, when I type in the thickness of 1 ounce copper (.00135) for the extrusion depth, it balks and won't let me go any lower than about .003".  I tried extruding teh part 1.000" and then subtracting .99865" away to leave a .00135" thick part, which it will let me do, but them there is no model left over.
Is this an inherant limit in Pro/E, or is there a setting I can change to go to a .00135" thick part?
RE: Part Thickness Limitations
check your accuracy
there are some config options with that too
accuracy is under edit> setup> accuracy
wf2
Where might I find that option?  Is it accuracy_lower_bound?  If so, what configuration file does this parameter live in?
It does not matter what file it is in as long as it gets loaded.  Pro/e loads 3 by default & you can manually load others.
For circuit boards you will probably want to convert to absolute accuracy and set it smaller than your .00135".
I think I would set:
enable_absolute_accuracy yes
default_absolute_accuracy .0005
Or create a start part with those settings.
