Drop pressure in a valve where fluid is high pressured propane
I need to find a relation between flow rate (m3/h) and diameter of the pipe or full opened valve to calculate the pressure drop between to sections when the fluid is propane at high pressure. Or which equation must I apply in this case?
RE: Drop pressure in a valve where fluid is high pressured propane
Is it a length of pipe, or a full open valve, or both?  Do you know the pressure upstream, downstream or both?  Do you know the flowrate?
http://virtualpipeline.spaces.msn.com
Crane 410
