Intersection point in drawing-module
I wonder if it´s possible to find an intersection point in the drawing-module. I know that this commando is available in other CAD programs.
/JJ
RE: Intersection point in drawing-module
Thanks David! You are the man of the day!
Nice video. But how do I measure an intersection to a center line as a diameter?
And how do I get a point in a scetch at an intersection?
Badtrick,
If I am understanding you correctly, you are wanting to place a dimension between the centerline and an apparent intersection. Follow the steps shown in the video but select the centerline as one of your edges, then before placing the dimension RMB and select Dimension Type\Linear Diameter.
Select the Point tool, RMB and select Intersection. Pick two lines.
David
