Flow Works Boundary Conditions
Hello, i am new to cosmosfloworks. I have been playing around with it for a bit now, and read up on all the help files and tutorials. I still don't understand how to apply boundary conditions using lids. I get this same error when picking the faces. Face <1>@Lid-1 is not laying on the boundary between solid and fluid region. Sometimes it works and sometimes it does not. I cant figure out a clear guideline on how to set these lids, for example, Does the matting have to be a certain way, or the computational data cover a certain region. If anyone can give me a few pointers, i would appreciate it.
Thank you
Thank you
RE: Flow Works Boundary Conditions
I ran up against the same error message "Face <1>@Lid-1 is not laying on the boundary between solid and fluid region", when I erroneously selected a surface of the lid not contiguous the fluid region, or when the computational domain was no set as I was figuring. My advice is to run the FLOWORKS>TOOLS>CHECK GEOMETRY before start to Solve the Analisys.
Best Regards,
Mirko
http://66.223.111.93/License_faq/FAQID__x017.htm
back in v.2004 I noticed that it frequently helped to avoid tangency between curved faces: replace it with planar "contact" instead, if you can...
