SA 105 impact test values
Just a quick question - I'm looking for criteria for impact testing SA 105 with a 50F MDMT. I've found supplementary requirements for SA 516, but no such parallel for SA 105.
Any guidance would be appreciated.
RE: SA 105 impact test values
Check ASME Section VIII, Div 1 Part UCS.
UCS (in particular UCS-66) has required impact testing for both my SA 516 and my SA 105 materials. I am now trying to figure out what are acceptable values for the impact tests for the 105 material.
I have just stumbled on UG-84, which appears to have average impact values that would apply to both the SA 105 and the SA 516. Does this table correspond to the supplementary requirements in section II?
EJL
you say ucs-66 is requiring impacts of 516 & 105 at a mdmt of +50
is this steel 10" thick?
you may want to apply normalizing to get to a different curve.
