"Save as pdf" using autocad colors
hi
i just started using the "save as pdf" feature in SE. the problem is i use autocad style colors (black background/white object lines). when i save it as a pdf, the white lines do not show up, even if i set it to save as black and white. i would like all the lines to print black, but different lineweights. does anyone have a solution to this? thanks
